TwinTurbo.NET: Nissan 300ZX forum - The standard on a TT engine is 171. I have yet to read
PiotrC70
on August 23, 2012 at 1:10 PM
Re: Did you recheck the compression numbers?
posted by SaphireZ
on August 21, 2012 at 10:56 AM
anyone having perfect pressure on a used engine. Verify your gauge. I used a new compression tester and found out the gauge was 20psi off.
1993 TT. R.I.P. 09.15.2010
can bad timing cause low compression?
SaphireZ
11:41:18 08/20/12
It would be the timing belt being off, not the cas position.
Woody75 (Denver)
13:27:39 08/20/12
PROBLEM SOLVED = CAS Sensor
SaphireZ
21:11:18 08/20/12
dude...my car is giving me the exact same numbers!
RonDeezy
22:58:51 08/20/12
Not gonna make a difference. (n/m)
Woody75 (Denver)
10:48:09 08/21/12
Woody75 (Denver)
10:47:45 08/21/12
SaphireZ
10:56:31 08/21/12
How were you doing it before?
Woody75 (Denver)
11:02:09 08/21/12
WOT vs plate closed is the difference, I think. (n/m)
Haasz32
11:22:41 08/21/12
shouldn't matter if the balance tube is removed (n/m)
aliaZ
19:52:40 08/23/12
The standard on a TT engine is 171. I have yet to read -
PiotrC70
13:10:23 08/23/12
A compression test is a relative test
BlackholeZ
18:44:19 08/24/12
